IDing a dodge camshaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2010, 04:21 PM
My buddy is trying to find out the specs on the cam he pulled from a 1985 318 he is rebuilding for his 1973 roadrunner project. There are a few numbers on it. Stamped prominently at the 6 o'clock area are the numbers 1828 and upside own under that are the numbers 182840. There is also SR stamped into it. At the 12o'clock there is 69-05 but Hughes said that those numbers are casting number. lightly stamped are the numbers 7 or 2, 8 or 9 or 3, and 8. Hughes makes a camshaft with 1828 in the part number but it is a roller cam and this one is not, well the lifters aren't roller.
Old 09-10-2010, 04:51 PM
techinspector1's Avatar
Wiki Edits: 326
Set the cam up in the block with crank and timing set and degree it.
http://www.iskycams.com/camshaft.php
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
camshaft question crussell85 Engine 21 07-24-2010 09:42 PM
Rotella Motor Oil boss350 Engine 14 04-17-2007 11:00 PM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
How to choose correct camshaft Drag1racer Engine 0 07-08-2005 04:04 PM
