Idiot light for trans temp. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2011, 08:17 AM
Anybody using an idiot light to signal when the trans fluid is getting 200 degres? I'm using a 700r4 and I'm told that overheating can happen and destroy the trans. I do not have a spot for a tranny temp guage but I could add an idiot light. What sender should I use and where to install the sender? Thanks :
Old 12-23-2011, 05:10 PM
transmission temp.
Best place for the sensor is a bung in the pan,thats where the fluid is the hottest,not in the cooler lines. If you are going to the trouble of installing,make room for a guage. They used to call them dummy lights,now idiot light because 99% of the time when they came on TOO LATE Dummy its wasted. If you can't put a bung in the pan you can buy 700r pans with them in allready. No need to even spend the money if in the end you are relying on a idiot light.
Old 12-23-2011, 06:49 PM
Semper Gumby
Wiki Edits: 2
Trans temp idiot lite
My 4Runner came with that very "feature" - an idiot lite that serves dual purposes - it comes on if either engine oil temp or trans fluid gets too hot. Of course, the definition of "too hot" is what the Toy engineers decided and having just a light means you cannot monitor how close things are getting to being "too hot".
I'd prefer to have both a light AND a gauge, so I can monitor things on an on-going basis and then have a light in case things go suddenly very wrong when I am not looking at the gauge, but that'd mean some real problems in hooking things up
Old 12-24-2011, 11:11 PM
SSedan64's Avatar
A Gauge with Warning Light would be best.
The Temp in the Pan is more of an average temp. the hottest fluid comes out of the TC/Torque Converter then goes to the Feed/Out Line to Cooler in the Rad. Return/In Line, cooled Fluid, goes to the Trans Lube circuit.
Many Circle Track etc.. gauge panels come with Gauge & Light.
Old 12-25-2011, 08:13 PM
Does anybody know on a 700r4 which line nto put the temp probe in? The upper or lower on the transmission case. Thanks
Old 12-27-2011, 03:49 AM
SSedan64's Avatar
Trans Fittings:
Line Out/Feed to Cooler = Bottom.
Line In/Return from Cooler = Top.
Radiator Cooler Fittings:
Line Out/Return to Trans = Top.
Line IN/Feed from Trans = Bottom.
Auxillary Cooler Fittings:
Line IN/Feed from Rad = Bottom.
Depends on if you want to know Temp before cooling or Temp after it leaves the Cooler/Coolers.
I'd keep an eye on Temp returning to Trans from Cooler = Top @Trans..
aftermarket idiot light kleen56 Electrical 2 11-12-2010 08:15 AM
Idiot light hookup Mrwood Electrical 2 09-11-2010 06:25 PM
Idiot Light to Gauge MI2600 Electrical 4 08-06-2007 12:28 PM
Idiot Light for an Alternator Nailheadforty Electrical 3 10-27-2003 02:29 PM
Idiot light ? Screwy Lewy Electrical 2 07-13-2003 11:31 PM
