Idiot Proofing My Trailer Wires - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2007, 03:51 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Hey Y'all
I am looking for a way to simplify & idiot proof my trailer wires .
I know I know its only 7 wires!
But Dammit to hell it gets confusing.
To Start I need a 7 or 8 circuit box it either fuses or circuit breakers Why Because I'm tired of chasing burnt wires because some one Else's trailer is wired wrong.... Different.
Now if I were to find such a circuit breaker set up how many amp breaker would you recommend I put on each line?
I have a 12 volt battery for my winch. that I like to run what some use as the "reverse" lights the center of the 7 way to power my battery/winch
AND on top of that I have a 12 battery for the break away box .
so I am looking for I guess 2 circuit boxes one for the truck & one for the trailer.
They need to be the same I have this one box that I pulled off a old boat that I thought was promising with a couple of relays in it but I have too much spaghetti as it is .
I need to keep it simple
ANY ONE got what I am looking for or do I have to build it because no one in this area even gets what I'm talking about.
Hell they don't even know what 7 stranded trailer wire is{well 1 guy he want $5 a foot for it!}
Another thing I fon't get is why don't the color codes on the plug match up with they way the wires really need to be
UUUUGGGGHHH!!!!!!!!!!!!!!!!!!!!!!!!
OK thanks
R
ID:	20749   Click image for larger version
ID:	20750   Click image for larger version
ID:	20751   Click image for larger version
ID:	20752   Click image for larger version
"SlowRide66"
"Illegitimis non carborundum"
Old 04-26-2007, 05:53 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
When I built my trailer----way back in the 80s----
I actually ran some 1/2" electrical conduit down the length of the trailer.
At the second crossmember next to the "A" tongue, I mounted 4 fuses.
(should be able to get these breakaway fuse strips at Radio Shack)
Left & Right Signals, Taillights, and Electric brakes.
I just used different colors of 14ga stranded THHN electrical (home Depot) from the fuses back to the lights and brakes, and for the section that plugs into the truck---(my plugs are six pin round) some cable similar to SOW wire with 5 conductors. I cannot remember if I got that cable from the Home Depot or a trailer supply.
This has been in use since 86, with no issues, except with the occaisional ground wire breaking on the truck side. I finally got tired of that so I now use a piece of wire with heavy-duty aligator clips to connect the truck and trailer ground now.
I am not sure, but I have never seen a 7 conductor wire that is colored the way it is supposed to be---yellow, green, brown, blue, white, red, xxxx.
yel grn brn blue wht red ???
Left, Right, Tail, elec brakes, ground, Aux, ?????
Bryan
Old 04-26-2007, 06:29 PM
Rob Keller's Avatar
Wiki Edits: 38
see this kills me!!!
black to be the power?! Ugh!
I found a nice fuse block but no circut breaker blocks
ATO 12 leads with ground bar {sweet} for $32.fiddy
Kool Site
Jack Rabbit
Really KEWL Site
cooper bussman {i mean really kool}
R
"SlowRide66"
Old 04-27-2007, 06:55 AM
Bryan59EC's Avatar
Black 12v
My guess would be RV trailer lighting---which would almost make some sense
Cause somwhere it might tie into AC wiring----
Not too sure about this
No RV
I prefer a motel with satellite
I believe the 7-pin plugs are designed for RV use and Semi trucks
5 and 6-pins for the people moving horses, cattle, cars and such
4-pin really light trailers with out brakes-----Boats
Bryan
Old 04-27-2007, 07:05 AM
Rob Keller's Avatar
Wiki Edits: 38
Well I guess I'm on my own here, I know the next SOB that scabs or chops my wires is gonna lose a finger or two!.
Off to get some more wires.
Oh By the way those Ratcheting crimper's seem to work pretty well $25. @ Auto Zombies
Thanks Bryan!
I'll let ya know if I get it idiot proofed like Kevlar sheathing with current interruption, monitored GPS allert with instant response.
Ill hook a damn tazer into it !go mess with my wires
mumble mumble grumble
R
"SlowRide66"
Old 04-28-2007, 02:29 PM
Rob Keller's Avatar
Wiki Edits: 38
Hey Bryan!! Check this Chit out!!
Now how come with all the truck drivers & mechanics here @ HR.com I had to find this on my own?
Oh well wish Id found this 20 years ago!!!!!
R
ID:	20838   Click image for larger version
ID:	20839   Click image for larger version
ID:	20840   Click image for larger version
"SlowRide66"
Old 04-28-2007, 04:15 PM
Bryan59EC's Avatar
WOW
Never saw one that was that big----most are the little 1-1/4 DIA
That thing looks to be 3+inches-------is that other thing a fuse block??
For those that dont mind cutting donut size holes in the bumper---that connector shoud be very good for big heavy wires and monster winches.
Now----tell us where ya got it
Bryan
Old 04-28-2007, 07:38 PM
docvette's Avatar
Wiki Edits: 12
Originally Posted by Bryan59EC
WOW
Bryan
Doc here,
Commercial Vehicles, Class A RV's, Commercial Mobile Generators and power plants, COW'S, marine applications and (what I deal with a lot) Mobile Television production trailers and news vans, will all use these type or "Arc~Tite" fittings..Retail they can get a bit spendy..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 04-28-2007, 10:41 PM
Rob Keller's Avatar
Wiki Edits: 38
NAPA!!
$40!!!!!
Ididn'tnotknowallthatwasstuckbehideoneofdemdarethi ngs!
I have not got it yet
the 2nd thing is a junction box for trailers but no breakers or fuses
although there is a nice multi port breaker set up she showed me in the book that will work nice with it
I still cant get ever that breaker thing its SO kool!
R
"SlowRide66"
Old 04-28-2007, 11:12 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
I have a NICE bullet proof DIY project for this..that looks good, performs well ( already better than my EX offered me ..) And will last longer than a Roach in a garbage dump..
BUT I depends on how serious you are about it, and how much you want to spend to make it right..(Hummm...Something my Divorce lawyer told me..)
Requires some minor welding, (well, maybe..) , Enclosure drilling and mounting, grinding, painting (sounds like my EX getting ready for a date..)
Conduit runs & Bending, $45 Fazools worth of Resettable Aircraft type Klix~On Breakers, 10 or so feet of 8 Conductor S.O. Cord (where you got your plug at) About $75 Fazools worth of Misc Hardware, and About, Between 100 and 150 fazools for a proper steel, water tite / vapor tite enclosure.
The real killer is the cost of long, 10 and 12 gauge wire runs..wire cost has gone through the roof..
Anyway..If your REALLY serious about it, willing to spend the scheckels to build it, I'll post it..It's not hard to build..but it' ain't cheap either..BUT you'll only have to do it once
Doc
Innovations
Old 04-29-2007, 06:29 PM
Rob Keller's Avatar
Wiki Edits: 38
Well as I've spouted previously {all my life}
I'm Not Cheap Just broke.
I am always up for bullet proof!
Yep er!
Along with my head lamp redo times two {Burb & Beast}
It will get done some day Just don't know the date
LOL
But I can start putting together the pieces & parts.
Please don't keep me in suspense much longer
I have a few ideas bouncing around in my head ,but I'm certain they will not be as elaborate as yours.
Is this Doc Vette ~~
or Duke the dog selling off the secret family recipe?
LOL
OK I'm Ready.
R
"SlowRide66"
Old 04-29-2007, 07:06 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Ok..,
Let me Finish typing it out in notepad..about 1/2 way done...(it aint short of steps either..) and I'll post it Monday or Tuesday back here..
I grew up in the age when WWW, HTTP, JPG, BITMAP, Meant ONLY one thing..you weren't going to pass typing class AGAIN this year..
Hunt....peck..Hunt...Peck...
Doc
Innovations
Old 04-29-2007, 07:21 PM
Rob Keller's Avatar
Wiki Edits: 38
Thank God for Click ~Scan ...Copy & Paste!!!
Thanks Doc!
R
"SlowRide66"
Old 04-30-2007, 11:22 PM
Might be cheaper just to quit letting people borrow the stinkin trailer. Or at least charge them a hefty deposit.
Or maybe make up a "trailer simulator" so you can at least test their setup before your stuff gets toasted.
Old 05-01-2007, 05:23 AM
Rob Keller's Avatar
Wiki Edits: 38
YEP ER!!
From now on if you want to borrow my trailer it comes with my truck & me driving & you footing the bill Cha Ching$$
My Profit or My pleasure Sorry 'bout yer luck!
I have a home made version in my mind, I have see a kit , A one man check kit for like $300.00!
Damn thats expensive for a checker
Good Ideas thanks!
R
"SlowRide66"
help needed for wiring idiot cares Electrical 3 06-17-2006 02:34 PM
Car hauler trailer questions (???) M&M CUSTOM Hotrodders' Lounge 25 12-25-2005 08:08 PM
350 spark plug wires toddtheodd Electrical 4 01-07-2004 02:31 PM
sparkplug wires pimpin72 Engine 14 09-26-2003 05:18 PM
