idle air controller - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2008, 05:16 PM
runn141's Avatar
idle air controller
what is the best thing to clean an idle air control sensor? starting fluid, carb and choke cleaner or brake parts cleaner?
this is on a 97 gran prix with a 3800 series 2 v6.
Old 11-04-2008, 05:50 PM
Wiki Edits: 31
throttle body cleaner.. do you mean the valve or the stepper motor? there really is no sensor for an IAC that I am aware of
Old 11-04-2008, 06:21 PM
runn141's Avatar
here is a picture of it.
Old 11-04-2008, 06:56 PM
Last wiki edit: Hand cleaner Last photo:
Wiki Edits: 3
thats the IAC, or Idle Air Control, its a stepper motor.
you can clean it with spray carb cleaner.
starting fluid won't do much and brake clean won't do anything.
normally you don't need to pull it out of the throttle body, just spray some carb cleaner into the port where its at. it doesn't take a lot of cleaner, just a shot for a couple of
seconds. if you can, start the motor up & give a few shots of spray waiting a few seconds between spraying it.
if you do pull it out to clean i, don't pull the pintle all the way out of it, that usually will damage it.
Old 11-05-2008, 01:47 AM
Barry.M's Avatar
Old Phart
Last wiki edit: How to identify a Ford V8
Last journal entry: 27 T Roadster project-For Sale
Wiki Edits: 3
You can also use Kero or Hydrocarbon based cleaning solvent as well. Watchout for the O Ring seal.
Old 11-05-2008, 10:38 AM
Wiki Edits: 31
brake cleaner and carb cleaner are basicly the same thing. with carb cleaner being only a tad more harsh
Old 11-05-2008, 08:58 PM
Rumor has it that some of those parts have an anti-corrosion coating on them that can be damaged by ordinary carb sprays. Dedicated throttle-body cleaner supposedly won't damage the coating, so that's what I use on mine.
Old 11-06-2008, 01:37 AM
Wiki Edits: 3
not the carb & brake cleaners i use.
the brake cleaner i use won't cut into the paint in seconds like the carb cleaner will.
the carb cleaner i use will etch the paint in just a few seconds. if its left on the paint for 30 seconds, it just may take it down to bare metal.
Respectable paint on 120V compressor? Slickriffs Body - Exterior 43 06-10-2010 02:01 AM
Carb tuning issues - 750 speed demon lightningcow Engine 48 07-01-2009 07:32 AM
Timing/carb idle mixture adjustment DENCOUCH Engine 7 07-21-2008 11:50 AM
Air bleeds Holley HP (idle & main) Bumpstick Engine 0 07-14-2006 07:38 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
