Idle circuit screws keep backing in and out - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2012, 11:46 AM
scapegoat's Avatar
Hey guys, got a proform double pumper on my 6.0 LS motor. I am having trouble with the idle circuit screws moving around. I get them tuned just right and then after a couple rides they are in a different spot. One even fell completely out and was laying on the intake.
Old 07-09-2012, 11:59 AM
Banned
they must be pretty worn. try wrapping some Teflon tape around them a few times.
Old 07-09-2012, 12:24 PM
scapegoat's Avatar
Its funny you say that. Carb only has around 3k miles.
Old 07-09-2012, 12:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Is there a place for the cork seals like Holly carbs use to keep their idle mixture screws tight?
Old 07-09-2012, 12:32 PM
scapegoat's Avatar
Wondering now if it came with them or not. I will go take a look.
Old 07-09-2012, 06:43 PM
T-bucket23's Avatar
Wiki Edits: 26
Some require springs
Chet
Old 07-10-2012, 02:34 PM
ericnova72's Avatar
More for Less Racer
Some aftermarket blocks take an rubber O-ring instead of the standard Holley cork gasket.
Should be one or the other though, to prevent air leaks and the problem you have of vibration making them move.
No springs are used here
Old 07-10-2012, 05:19 PM
scapegoat's Avatar
Well guys I just checked and all four screws have the cork/paper gasket thing. I don't know why they are moving.
Old 07-10-2012, 05:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I suppose there's a chance the cork has dried/shrunk, if in doubt, install a fresh set. Might as well get the new screws to go w/the seals if they're the same as yours- it's actually cheaper to buy the idle screws and seals than just the seals!
If there's a NAPA or other good parts store in your area you can look through their rubber O-rings for a suitable replacement for the cork seal. I can guarantee you the rubber O-rings will be a LOT cheaper than buying the cork seals from Holley, you can get a lifetime supply for the cost of the cork ones.
4150 idle circuit ballsout1 Engine 6 11-28-2010 01:30 PM
Idle mixture screws not working V305 Engine 7 10-05-2008 07:15 AM
Holley idle circuit baddbob Engine 2 08-19-2007 07:43 AM
idle mixture screws 72Orange Engine 14 09-28-2006 01:30 AM
Idle Screws Do Nothing?? (holley) STBR Engine 11 10-11-2003 09:49 AM
