idle in gear ?????????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2010, 06:36 PM
sickolds's Avatar
sickolds
i have a chevy 383 224/224 465/465 lift 9.7 compresion it idles raly smooth at 800 rpms and drops down to 500 in gear and idles smooth it has a stock stall converter wen it is in gear it feels like it pulls a lil so i drop the idle to 700 and it drops down to 400 in gear feels better butt what should the idle be in gear i know people are going to say that i should get a higher stall converter but i just did a b&m rebuild to the trans and im all out of money oh the trans is a th350 plus i was told that i didnt need a stall converter with these cam (thats what summit said)
Old 08-01-2010, 06:41 PM
"Permanately Banned"
I'm curious...What's the stall on your stock converter?
Roach
Old 08-01-2010, 06:42 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Where is your initial and total timing? That kind of cam will want considerably more initial timing than a stock type cam, probably at least 14~16 or more.
Old 08-01-2010, 06:43 PM
sickolds's Avatar
sickolds
i dont know
Old 08-01-2010, 06:44 PM
sickolds's Avatar
sickolds
i dont know how do i find out
Old 08-01-2010, 06:45 PM
sickolds's Avatar
sickolds
timing is 14
Old 08-01-2010, 06:49 PM
Rickracer's Avatar
Try 16, then 18, and see how it works,
Old 08-01-2010, 06:51 PM
sickolds's Avatar
sickolds
it runs very good with 14 i just want to know about the idle
Old 08-01-2010, 06:58 PM
sickolds's Avatar
sickolds
i know that timing has every thing to do with idle but the car runs really good i dont want to start moving all kinds of things and end up f ing it all up
Old 08-01-2010, 07:23 PM
sickolds's Avatar
sickolds
well i guess i came to the wrong site
Old 08-01-2010, 07:43 PM
Rickracer's Avatar
No, you came to the right site with the wrong attitude or wrong expectations. There is no magic bullet. 2 more initial timing will not F things up, it WILL help. Part of the reason it pulls down is stall speed, the more torque you make, the higher your stall speed goes, the more initial timing you have, short of detonation, the more torque you will make. Make sense?
Old 08-01-2010, 08:15 PM
sickolds's Avatar
sickolds
so if i change the timing to 16 the idle wont drop as much help me understand
Old 08-01-2010, 08:20 PM
Overdriv's Avatar
I guess I'm a bit confused as to what the problem is?
It will idle down to 500 RPM in gear and wants to pull a little. Sounds normal to me.
Old 08-01-2010, 08:25 PM
sickolds's Avatar
sickolds
thats what i want to find out is it normal what is the idle in gear
Old 08-01-2010, 08:28 PM
sickolds's Avatar
sickolds
the people from summit said that i did not need a stall converter
400sbc want idle in gear Lmurphy Engine 6 07-24-2010 01:28 PM
Edelbrock 750 tuning GCD1962 Engine 34 04-16-2008 06:03 PM
Cam lope question joeford Engine 4 08-10-2006 08:14 AM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
Idle in Park is 1,800 RPM....Idle in gear in 900 RPM...Way too High. white66coupe Engine 11 09-10-2004 11:49 AM
