Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - idle gremlins
Thread: idle gremlins
Old 08-18-2012, 04:57 PM
SJSS SJSS is offline
So after letting it run at a high idle for a while I checked for vac leaks and came up empty handed, as a last ditch effort I messed around with the idle screws checked timing and all connections then tried to bring the idle down and voila! It was happy chugging along at 750ish rpm... Could idle mixture cause an erratic idle? If my battery was close to dead and the alternator wast charging it could that cause an erratic idle?
