idle issue with a new engine - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-30-2012, 09:04 PM
gonzo08383's Avatar
Last journal entry: brakes
bird, you mention the pcv sys. the valve works fine, hose from manifold vac to valve to valve cover, standard setup. the other valve cover has two breathers. sound about right? the carb base is manifold vacuum so it shouldnt matter so long as its manifold vacuum sourced right? the cap and rotor are fine. accel super coil, cd ignition box, and the .060 gap is what was told to me by a tech line at msd cuz until i re-gapped the plugs i was burning them up and detonating, an extra .030" shouldnt make that much difference with a 60,000 volt coil right? oh and i converted to a secondary metering block so the carb has a quick fuel baseplate, a quickfuel primary and secondary metering blocks, pform 750 body, holley 4160 style side hung fuel bowls. i'm curious if the combination of parts allows four corner idle? if i back out the secondary blocks "idle" screws it runs worse. i always left them closed, dyno mechanic siad the last setup was pretty dead on. i think i'm at the point where i should leave it be for awhile cuz now i'm thinking of all kinds of ideas instead of keeping it simple. think ima save up for a wideband. vac gauge and timing light only help so much
  #17 (permalink)
Old 05-01-2012, 08:41 PM
gonzo08383's Avatar
carb is tuned now. 78 pri/80 sec. never changed the air bleeds. 38*total timing, 26* @ idle. problem was electrical. there was a short between the steering wheel and the gas pedal(points to self). thank you bird for the info, starting over put me in a spot where i was forced to tell myself that what i already know isnt always fact. at one point in time when i first installed the carb the sec throttle blades were open. they somehow closed. i guess the allen screw backed itself out somewhere along the line. i also noticed the screws holding the baseplate to the main body were loose. a quick reset and no more burning eyes @idle. see, never a bad idea to doublecheck things. thanks all for the input. cheers.
Erratic idle issue I'm stumped!!! elcaminodragster Engine 18 10-28-2011 07:15 PM
Idle Issue vs. Cam Selection Jay Gadsby Engine 4 06-18-2011 08:28 PM
Idle issue - 96 ranger 406 bug Engine 3 03-15-2010 08:26 AM
Strange overheating/Idle issue. JoBlo Engine 8 10-22-2009 06:31 PM
Fast Idle Issue ruiner808 Engine 3 01-20-2004 01:20 PM
