Idle Issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2010, 08:10 PM
Idle Issues
I put some headers on my 73' 350 today. Now it wont idle. It cranks, idles crappy, then dies. If I give it some gas I revs upand will stay at higher rpm's fine. As soon as i take my foot off of it, it idles down then dies. Edelbrock carb and hei also on here if that helps.
Old 05-19-2010, 09:21 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Maybe the gasket at the base of the carb sucking some air .. They can start leaking at the strangest times . How long has the carb been installed 3 - 4 years, can be the life of the gasket . Check any hoses for a vacuum leak . Just a couple of ideas that come to mind .
Old 05-19-2010, 10:38 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
First, double check the routing of the wires- 1-8-4-3-6-5-7-2, and be sure the wires are all the way on. Recheck for a vacuum leak or line left off.
Then (if all was OK w/the wiring), try turning the idle mixture screw 1/2 turn out from where it is now. If that helps, hook up a vacuum gage or use the tach to adjust the idle mixture screws until you get the best vacuum/highest idle speed.
supercharger backfire through carbs 471A Engine 8 10-18-2009 09:25 AM
Help tuning 383 for street use strokey Engine 29 04-11-2008 05:51 PM
1967 pontiac 455 overheating brisk Engine 11 04-03-2008 10:17 PM
Too much camshaft!? pi71 Engine 22 04-10-2007 01:18 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
