Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Idle misfire ?????
Old 03-02-2006, 05:42 PM
motoxracer's Avatar
motoxracer motoxracer is offline
Idle misfire ?????
Got a 96 Dodge stratus with a 2.4L got a engine misfire at idle runs fine off idleI have changed the plugs and wires didn;t cure the problem,It sometimes dosent misfire even at idle but most of the time it will not bad enough to stall out but it's a pain the little woman gets nervious its her car,was woundering could it be the coil pack causing the misfire I also noticed that 2 of the plugs were burned down more than the other 2 ?? any help guys
