idle mixture - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2007, 03:08 AM
markzepp820's Avatar
idle mixture
I bought a used Holley 6170 carb and was wanting to know for the idle mixture screws, how many turns will be good for my stock sbc 350.
Old 01-30-2007, 09:55 AM
DoubleVision's Avatar
Use a vacuum gauge, set it at it`s highest vacuum reading.
Old 01-30-2007, 06:05 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
That is correct. It will be around 1 3/4 to 2 out.
If that won't work when you start the engine, then something is way too far out of wack.
Old 01-31-2007, 03:52 AM
re: idle mixture
kool, I'll try to get my hands on a vacuum gauge. I also heard you can use one of those digital tachs, getting the highest rpm reading. Is this true? Also, if I were to use a vacuum gauge, do I hook it up to a full vacuum port?
thanks guys,
Mark
Old 01-31-2007, 11:14 AM
elvis 66 chevelle's Avatar
66 Chevelle 406 SBC
idle mixture
Yes, hook it up to the constant vacuum port. that way you will have vacuum at idle to set mixture screws out to highest vacuum.
Vacuum adv.. underdog305 Engine 58 01-30-2007 12:19 PM
idle mixture screws 72Orange Engine 14 09-28-2006 02:30 AM
Cam lope question joeford Engine 4 08-10-2006 09:14 AM
Ported Vacuum 72Orange Engine 18 08-07-2006 09:56 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
