You have a fuel pressure and or carb float height issue. and or dirt is infecting
The carb needle seat assembly causing flooding. The carb is flooding. remove and repair. Get a fuel pressure eg or get the right fuel pump. 5-6psi. eg carter #P4070 5psi at idle max 6psi at idle . carbs throttles should be both evenly open at idle. idle mix screws should all end up more or less even. What camshaft? |
20-24deg base at idle 34-36 at max advance. 4" or 5" step up springs. vac advannce use ported. BOTH Carbs throttles base opening must be correct at idle. remove both carbs and preset the carbs idle throttle opening setting The idle fuel transfer slot should be jsut exposed at idle on both carbs at idle. If the carbs are too far open at idle (lack of spark advance at idle) the idle will be rich big Cams need more idle base timing If it is flooding with 4.75psi fuel pressure, there is dirt in the needle seat or the needle seat is defective or the float is out of wack. Get new fresh spark plugs |
| The Following User Says Thank You to F-BIRD'88 For This Useful Post: | ||
loafing1 (07-25-2012) | ||
| idle mixture adjustment | gary53 | Engine | 4 | 09-12-2010 02:19 PM |
| idle mixture | markzepp820 | Engine | 4 | 01-31-2007 10:14 AM |
| idle mixture screws | 72Orange | Engine | 14 | 09-28-2006 01:30 AM |
| A/F idle mixture ?? | voodoosurfer | Engine | 3 | 10-28-2005 10:47 AM |
