Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Idle in Park is 1,800 RPM....Idle in gear in 900 RPM...Way too High.
Old 09-07-2004, 09:57 AM
white66coupe's Avatar
white66coupe white66coupe is offline
Unhappy Idle in Park is 1,800 RPM....Idle in gear in 900 RPM...Way too High.
Hello,
Well, I'm trying to fine tune my holley 4160 (600cfm) and I have ended up with my idle in Park as 1,800 RPM (which is screaming) but then when I drop it in to gear in goes down to 900 RPM. Why the big change?
I guess my goal for both is 900 RPM in Park and in gear....any thoughts?
The only other info I have is that I opened the secondaries a bit to try and get a stronger idle, but that should be the same in park and in gear. Unless.....Because I had a faster idle with the secondaries open, I kept backing off the curb idle screw to lower the idle speed and now when I put it in gear, it almost wants to stall.
So...is it safe to say that the problem would be solved if I close my secondaries a bit and crank my curb idle screw up again (which I was trying to avoid) and maybe my idles would even out? Or is there a bigger problem here?
Thanks, Greg.
