Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Idle in Park is 1,800 RPM....Idle in gear in 900 RPM...Way too High.
Old 09-07-2004, 11:07 AM
ponykiller511's Avatar
ponykiller511 ponykiller511 is offline
New Member
You should set the idle screws to give you the highest possible vacuum (Or RPM if you dont have a vac guage) then back down on the idle screw. There will be a slight change when the car is placed in to gear, say 850-900 in N, 750 in gear. Why have you opened the secondaries?
JK
