Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Idle in Park is 1,800 RPM....Idle in gear in 900 RPM...Way too High.
Old 09-07-2004, 12:09 PM
ponykiller511's Avatar
ponykiller511 ponykiller511 is offline
New Member
any vac leaks?
If you need the back barrels to open sooner use a lighter spring. By opening the back barrels you are allowing more air into the engine but not fuel . Prob. works fine for no load, but too lean when the engine is under the load of the transmission.
