Today after work I put $30 in Cam2 in m car.Ran fine after cruising the boulavard for about 45min it began to idle rough and low rpm.Got it home arked it.Went to the store at around 3am got in pumped it once cause its cold tonight.Fired it and it was idleing at around 350rpm and sputtering reved it to clean it out didn't help ran rough all the way to 1200rpm.Got it to the store.Poped the hood raised the idle and fooled w/ air/fuel idle started to race brought it down ran ok.On the way back it won't stay running unlees your foot is in it.
Will check it today and see any ideas???Plug wires not laying on headers,carb has no choke.
I'll check for obvious stuff like vac leaks,loose dist,etc... Didn't care much at 3 I just wanted my crap from the store.
