Idle problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2011, 10:10 PM
Idle problems
Ihave a SB350 with Elderbrock intake and 600 Holly. My problem is the idle screw is completely turned out and the motor idles to fast when timing is correct. Besides the idle screw is there another way to adjust idle?
Old 01-27-2011, 12:58 PM
DoubleVision's Avatar
The secondary`s have a adjustment as well. If the secondary plate is open too far it`ll pull fuel out of the boosters and the car will idle high.
The secondary has a adjustment on the bottom of the baseplate so the carb has to be removed to adjust it. Or the secondary`s are sticking partially open which is what my Demon used to do, I could reach over and force them shut with modest pressure, but they wouldn`t reopen so I had to remove the carb anyway and sand out the high spots in the throttle bores so they would operate correctly.
Old 01-27-2011, 01:58 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You positive there's not an open vacuum port or a vacuum leak somewhere?
Also be positive the fast idle cam isn't sticking.
Old 01-27-2011, 09:21 PM
bubbahotep's Avatar
check too that the throttle linkage isnt stuck or not adjusted. Remove your throttle linkage and see if it affects the idle
Old 01-27-2011, 09:49 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
My guess would be like cobalt said vacuum.
Q-Jet Idle Problems Crush1 Engine 11 12-16-2015 04:04 PM
idle problems Dash2184 Engine 4 10-03-2006 09:34 PM
SBC idle problems 97Z28 Engine 8 08-16-2005 01:00 PM
Idle problems 85cutdog Hotrodding Basics 10 06-16-2004 10:00 AM
SBC idle problems need help zukgod Engine 2 06-10-2003 11:17 PM
