Idle problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2004, 01:12 PM
New Member
Idle problems
I have a 305 tbi motor and when I start it, I have to keep giving it gas to keep it started. When I put it in gear I have to two foot it to keep it going untill it gets warm. If I'm driving and I push the gas all the way down it gurgles and acts like it wants to stall but will sloooowly pull out of it. Is this a timing issue? If so how to correct it.
Old 05-20-2004, 05:06 PM
73chevyhelp's Avatar
would guess its the choke not operating correctly,but i dont know with a throttle body.
Old 05-20-2004, 05:45 PM
Tim240Z's Avatar
Not too familiar with teh TBi stuff, but check the usual suspects:
Vacuum leaks
Idle control valve (stepper motor I believe)
Old 05-21-2004, 12:27 AM
61ChevyTruck's Avatar
Yeah, I did set-off your alarm
Fuel Filter clogged?
Old 05-21-2004, 08:16 AM
try tuning the idle up on the carb
same thing happened to me when i was working on a car. it was a 305, i dont know tbi morters very good tho
Old 06-14-2004, 02:22 AM
rocknrodder nz's Avatar
Last journal entry: Dug up some old pics
timing could be way retarded, give the dizzy a bit of a turn and see what happens
Old 06-14-2004, 01:43 PM
4 Jaw Chick's Avatar
Distracted by shiny objects
What year vehicle are we talking about? Could be one of the electronic sensors. I. E. Oxygen sensor...
Chickie.
Old 06-14-2004, 02:09 PM
Siggy_Freud's Avatar
Sounds like a possible vacuum leak or lack of fuel pressure. I'd do a leak test with some starting fluid (be careful though) and then hook up a fuel pressure guage and see where its at. Should read between 11-13 psi. See what happens when you give it some gas. Shouldn't drop at all.
Hope this helps.
Bringing history and technology together.
Old 06-15-2004, 12:31 AM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Running too lean on the carb?
Alan
54 Chevy Pickup
Old 06-15-2004, 01:56 AM
have you got it sussed yet man, we all wanna hear what is causing this
Old 06-16-2004, 10:00 AM
New Member
Sorry about the delay. Didn't have the time to work on the car like I wanted to but it seems like the vacuum system has a leak and the timing was off and I'm now in the process of puting it back together. Thanks for the help and I'll let u know how it turns out.
