Idle RPM? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 06-27-2009, 11:44 AM
Alrighty well i got the car running, got it up to 190* idling at 1400 with the choke open, went to go give it a rev and the carb caught fire it didnt really backfire but I dunno. I am not using a aircleaner as well. I have the mixture screws at 1 full turn out.
  #32 (permalink)
Old 06-27-2009, 11:56 AM
001mustang's Avatar
Can you get idle set to produce white plug at 600-900 rpm?
  #33 (permalink)
Old 06-27-2009, 12:02 PM
I had it at 600-700 and it just wanted to die. I'll raise the RPM's a bit more. see where it goes from there, the plugs dont look fouled or anything more than they were after I cleaned them up.
  #34 (permalink)
Old 06-27-2009, 12:42 PM
001mustang's Avatar
OK. I would get the idle tuned in before diagnosing the other problem.
If idle is tuned in lean then the plugs should start turning white.
Also, it is possible that some plugs are still fouled if they didn't clean up all the way.
Did you photo the cleaned plugs?
  #35 (permalink)
Old 06-27-2009, 02:41 PM
Forgot to take pictures of them, I'll go pull some and see how they look. Car is shut down for the rest of the day since I need a new T-stat. Temp started climbing past 200 with the fan on so I let it run a tiny bit more but once it got to 220 I shut it down. Coolant hose coming off the housing was DRY and when I pulled the housing it looked like this...
Amazing what one summer of water and not running much will do. I just put it into a pot of boiling water and it did open so I dunno but I'm getting a new 160*, should be in tomorrow.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Carb tuning issues - 750 speed demon lightningcow Engine 57 07-01-2009 07:32 AM
38 ply. rpm at idle ? flathead 6 p-6 38plymouth Engine 2 04-13-2009 10:52 AM
DARK brown--BLACK plugs SBC Joshua Lee Engine 130 02-03-2008 09:12 AM
Idle RPM The Vandal Engine 1 07-12-2003 08:07 PM
