Idle RPM goes down when dual electric fans are switched on - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2010, 09:11 PM
BigLeoRocks's Avatar
Hey fellas,
When I switch on my dual fans the RPM drops noticeably. I just put in a 100 amp 1-wire alternator. It was not doing this before the new alt. but the old one was not charging at all. Thanks.
Old 08-10-2010, 06:52 AM
T-Bucket, Corvette, Mustang
The alternator is causing the rpm drop because of the additional electrical load imposed on it by the fans, especially when they first come on. As the electrical demand increases, the alternator will become harder to 'turn', thus the drop in idle rpm. This is not so noticeable when the engine is above idle such as when driving. My T-Bucket does the same thing when the fan comes on (I'm running a CS130 alternator).
Old 08-10-2010, 06:55 AM
delawarebill's Avatar
one wire alt's
those things don't like to charge at idle. but do fine running down the road.. just like rocks said.. big draw will reduce rpm's. i have one also and does exactly the same. but runs 14v down the road..
Old 08-10-2010, 01:00 PM
302 Z28's Avatar
Ditto what the others have said about the drag of the alternator. If it really bugs you, you could install an idle kick up solenoid like they use for A/C.
Vince
Old 08-18-2010, 03:31 PM
Thanks fellas,
I just raised the idle 200rpm. It sounds even nastier.
66 Caprice
538 HP 383
motor wont idle at less than 2200 rpm Pupsvette76 Engine 30 08-06-2010 05:02 PM
Carb tuning issues - 750 speed demon lightningcow Engine 57 07-01-2009 07:32 AM
Edelbrock 750 tuning GCD1962 Engine 42 04-16-2008 06:03 PM
Help tuning 383 for street use strokey Engine 34 04-11-2008 05:51 PM
Idle in Park is 1,800 RPM....Idle in gear in 900 RPM...Way too High. white66coupe Engine 11 09-10-2004 11:49 AM
