Idle speed in gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2010, 05:50 PM
bigdog7373's Avatar
Of course it's fast
Idle speed in gear
I have the idle speed set to 950 rpm in neutral, but when i put it in gear it idles at 400. I i was thinking about adjusting the idle mixture screws a little and see it i can fix it but it's dark out now. Is this most likely the problem or could it be something else? Engine is a chevy 350 with an edelbrock carb.
Old 12-30-2010, 06:20 PM
ericnova72's Avatar
More for Less Racer
Thats a big drop. Might need more initial timing along with mixture screw adjustment. Find your best idle mixture adjustment and then go back out 1/4-1/2 turn richer to help with this rpm drop.
Old 12-30-2010, 06:31 PM
bigdog7373's Avatar
Of course it's fast
Yes, it's annoying. I didn't think about timing. Maybe ill play with that a little also.
Richmond 6 speed gear oil viscosity... AllenKarber Transmission - Rearend 0 05-24-2008 10:22 PM
4 Speed popping out of 2nd gear under a load Nite Life Transmission - Rearend 19 01-07-2008 09:44 PM
M21 4 speed speedo gear, which one sapsz28 Transmission - Rearend 2 09-24-2007 09:57 PM
Noisy Richmond Gear 5 speed gzrmobl Transmission - Rearend 1 09-08-2007 07:34 PM
Tremek 3 speed gear pop-out hanajack Transmission - Rearend 0 02-17-2004 02:15 PM
