idle/timing for 383? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2006, 04:56 PM
fireforsin's Avatar
Novaaaa
just curious if someone could tell me what my idle and timing should be around with my engine. the engine specs are as follows:
"383" Chevy
350 block
400 crank
Comp Cams Hydrualic Flat Tappet 292 cam with .501" lift
world products s/r torque heads
crane gold full roller rocker arms.
750 cfm edelbrock carb stock rods and jets
2500 b&m stall converter
th350 transmission
if i left any important stuff out just remind me.
also i am up in reno, nevada so my altitude is pretty high, about 4500 feet.
thanks,
mike
