torquer 2 ? why didnt you go tunnel ram ?...lol
Idling at 1100 rpm, you may not be using the idle circuit and probably are in the transistion circuit.
I would loose the spacer first, get the carb to work then add the spacer. No sense fighting two items at once. Make sure you have NO vacuum leaks. How much vacuum do you hold at idle and what size power valve is in the carb? The number on the power valve needs to be 1.5 to 2.5 lower than the vacuum level at idle. IE 8.5 vacuum reading you need 6.5 or 5.5 power valve. Secondly, if you have the transistion circuit uncovered to make it idle, you need to either open the secondary slightly, or drill a small hole in each primary butterfly to allow more air at a lesser opening. |
I would check for the vacuum leak first, but you also said stock distributor. Don't use stock timing, you'll need a lot more initial to get that to idle well. I wouldn't be happy without a complete re-curve of that ignition. More initial, proper total, then an adjustable vacuum advance can.
I also agree that at 1100 rpms you're way into the primaries and off the idle circuit. You should be able to get a nice almost stock idle speed with that cam. More initial will let you drop the idle screw back down getting you back into the idle circuit. |
| Why not a 350 sbc? | bowtieorbust | Engine | 29 | 09-05-2008 09:43 AM |
| SBC 350 forced induction buildup | sickgrin | Engine | 8 | 09-13-2004 07:07 PM |
| Why is my sbc chevy 350 getting so hot? | batman09 | Engine | 17 | 08-22-2004 07:37 PM |
| Switching from olds 350 to chevy 383... and now I've got problems matching up trannys | elukas | Transmission - Rearend | 6 | 08-26-2003 12:03 PM |
| 0.060 over 350 sbc or 0.040 over 400 splayed cap sbc | tony350ss | Engine | 4 | 05-17-2003 09:02 PM |
