Idles fine but starts to misfire at 1500 rpm - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2007, 12:16 PM
70bird's Avatar
Smile if you know Jesus
Last journal entry: Waiting for a tranny
What gives? My truck started to misbehave this morning. It ran fine yesterday. It warmed up just fine. When I started to drive away, and as soon as it hits 1500 rpm it starts to misfire (or lose a cylinder). When in park it will not misfire. I disconnected the vacuum advance and no change. Fuel pressure looks good. All the plug wires seem to be attached well.
chevy 350 carbed, 12* initial.
Any other ideas?
Old 04-04-2007, 02:45 PM
how is the battery? a low battery will make an HEI misfire like that but it'll run fine at idle. Definately sounds like a spark thing.
Old 04-04-2007, 02:49 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Place foot firmly on brake, shift into drive, push down on throttle pedal and see if it misses and what RPM. Could be fuel related or choke still on. Changed the fuel filter lately?
Old 04-04-2007, 04:30 PM
70bird's Avatar
Battery is good. 6 month old optima.
I'll try the break and accelerator test when I get home.
I checked the screen in the holley a couple months ago.
Old 04-04-2007, 04:56 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Have the Module Checked, It is probably going thermal (breakdown under load) and if a new one is needed, have it tested also, they have a high OBF fail rate..like 1 in 3 or 5..and after you leave the store, it's your $30 problem..
Check the primary resistance on the coil, less than an ohm, but more than 000 on a DVOM, Set to R x 1 , calibrated to "000".
Check the secondary, Set to R X 20K or higher, it should be between 6,000 and 30,000 Ohms..Either outside of ranges indicates a failing coil, replace.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 04-04-2007, 04:59 PM
I goofed on my first qoute
Last edited by ranchwagon1; 04-04-2007 at 05:02 PM. Reason: goofed , wrong procedure for quotes
Old 04-04-2007, 05:05 PM
missing at 1500 rpm
Check out the counter weights on your distributor, a spring may have popped off, idle is usually good, but they can advance too much if a spring is broken or weak ..
Good luck
Ranchwagon1
Old 04-04-2007, 11:29 PM
70bird's Avatar
I was hoping for the easy fix of a spring but no cigar.
Doc,
I don't have a DVOM but I do have a multi meter that will measure rx1k and rx10.
How do I check primary and secondary resistance on an HEI setup? I have touched the button on the cap and the inner center prong the the MM set at Rx1k and get a 30 K ohm reading. My guess is this is a secondary resistance.
I cannot get a reading from any of the other terminals.
Old 04-04-2007, 11:34 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Measure between the BATT and TACH terminals..R X 1 , clibrated to "000"..
Doc
Innovations
Old 04-05-2007, 01:03 AM
70bird's Avatar
The Ohm reading came out good.
Does anybody know if the MSD Super HEI modules can be tested with the same hardware as an OE style module?
I think I'll stick the Birds distributor in the truck tomorrow after work and see how that goes. I wish I had though of that earlier today.
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 10:21 PM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
351 windsor running rich ???? ve3ham Engine 19 08-08-2005 01:48 PM
Is 2 1/2 pipes big enough? Mustang_Killa66 Engine 7 02-12-2004 09:04 AM
idles fine until in gear operationgetdown Engine 1 09-07-2003 11:54 AM
