Idles high - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-11-2008, 03:03 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
To reset the computer back to it's factory settings disconnect the battery, have a cold one or 2, or just wait 10 minutes then hook it back up.
  #17 (permalink)
Old 04-11-2008, 04:06 PM
dads asking me to post on here that we don't know exactly what the problem with the throttle but is there anything manually we can do to turn it down?
  #18 (permalink)
Old 04-11-2008, 04:34 PM
  #19 (permalink)
Old 04-11-2008, 04:37 PM
My 2 cents worth
Wiki Edits: 3
Not that I know of. Try disconnecting the throttle cable, maybe it is holding it open a little bit.
  #20 (permalink)
Old 04-11-2008, 06:12 PM
My 2 cents worth
Wiki Edits: 3
What is your manifold vacuum at idle? Do you hear any hissing sounds? Your question on the TPS(throttle position sensor) what is it where is it, it is located on the throttle body on the opposite side of the throttle cables.
To help determine whether or not it has a vacuum leak use a propane torch(unlit) with a hose attached and spray the propane all around the intake area. When it starts to idle the engine down with the added propane enrichment you will find where your leak is located. Also shoot some of the propane through the air filter intake, this will tell you if it is just running too lean.
  #21 (permalink)
Old 04-11-2008, 07:49 PM
BORTI's Avatar
BLOWN 357
idles high
The throttle body is easy to change,just four bolts.The throttle position sensor is on the throttle body itself.It has a couple of screws holding it in place and a couple of wires.If you have a stock cam,I would go no larger than 24lb injectors and maybe a 77mm mass air sensor.These things you can do yourself if you have tools and a guide.The ecm is the computer that controls the engine it is located on the passenger side kick panel.
  #22 (permalink)
Old 04-11-2008, 11:01 PM
awesome ty
  #23 (permalink)
Old 04-11-2008, 11:04 PM
My 2 cents worth
Wiki Edits: 3
Originally Posted by Toddclary
awesome ty
What? Could you expand on this?
  #24 (permalink)
Old 04-12-2008, 09:20 AM
Thank you guys for all your input and ill see what i can do to fix my problem.
  #25 (permalink)
Old 04-22-2008, 12:06 AM
Ever figure it out? If not, look for a big vacuum leak. My 5.0 T-bird decided it wanted to idle at 45-50mph with no power brakes any more. Turned out the cheezy little plastic vacuum manifold on the firewall inboard of the brake booster had a nipple broken off, causing a ~3/8" leak in the brake vacuum system. I fixed mine with a brass tee.
which oil pump for a 406? high volume or high pressure? 406 ss monte Engine 23 09-10-2006 07:48 PM
85' corvette idles high WakBordr7387 Engine 6 12-30-2005 12:33 PM
Can you build a High Performace Engine that runs idles smooth? Jag Daddy Engine 16 01-23-2004 02:11 AM
Emissions HELP cutsupreme Engine 33 12-27-2003 08:22 AM
More Info, High RPM to Shift on 700R4 Ted Bundy Transmission - Rearend 3 11-25-2003 05:44 PM
