Idles high - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2008, 04:11 PM
Idles high
i put a jegs "Max Box" upper sheet metal intake plenum, for shortys headers, BBK cold air induction system, and BBK high performance H-pipes with out converters, everything else is stock. The car idles high, even with the throttle screw screwed out all the way. What did i miss. How can i idle the car down? It idles at 1 1/2 thousand rpms, in park, and a little over 1 thousand rpms in gear. Do i need a chip or different program. that will idle it down?
Old 04-06-2008, 04:16 PM
BORTI's Avatar
BLOWN 357
High Idle
I had a similar problem on a 93 cobra.When I put shorty headers with no converters.I would check for a vacuum leak somewhere, on mine it turned out to be a hose under the car connected to the smog.
Old 04-06-2008, 07:45 PM
Be sure that you secondary throttle blades are closing all the way.
Old 04-06-2008, 08:19 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Is it hanging on one of the steps on the choke cam?
Semper Fi
Old 04-07-2008, 05:05 PM
all this was also happening before we changed all this so its not a new problem was just hoping changing this stuff may help it some. one guy above said
Can you explain this to me?? me and my dad are use to older cars with carburetors on them so the whole injection and crap is kind of confusing .
So if u guys could explain these questions u have for me a little better it would be awesome!!, and would changing the throttle body help any?? do you guys know what the stock 1991 5.0's throttle body size is??.
Old 04-08-2008, 09:31 AM
BORTI's Avatar
BLOWN 357
Throttle Body
The throttle body doesn't have secondary blades,the guy mispoke thinking you had a carb.The early 5.0 had a 55mm throttle body.You could upgrade to a larger 65mm it wouldn't hurt.
Old 04-08-2008, 09:40 AM
BORTI's Avatar
BLOWN 357
idles high
After reading the thread again I see you made some upgrades,the idle is high because its probably running a bit lean.A larger throttle body would help,and eventually putting 24lb injectors.And also a bigger mass air sensor.
Old 04-08-2008, 09:47 AM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Pull the EGR valve and see it you can blow through it. I have seen them stuck open by a piece of carbon and it has been the cause of a high idle. If you can blow through it buy a new one..
Old 04-08-2008, 10:54 AM
What is it or what was it?
Bogie
Old 04-10-2008, 05:19 PM
what do you mean what is it or what was it??
Old 04-10-2008, 05:24 PM
The engine and the vehicle it's in.
Bogie
Old 04-10-2008, 05:30 PM
engine and vehicle is a 1991 mustang 5.0. thats what a 302 i believe
Old 04-10-2008, 08:17 PM
Is it still injected?
Bogie
Old 04-10-2008, 09:13 PM
yup sure is
Old 04-11-2008, 02:57 PM
Help :)
http://forums.musclemustangfastfords...own/index.html
in here they are talkin about a Throttle position sensor.. what is that and or where is it?? could this be my problem??
"Did you you reset the ecm when you replaced the IAC motor?"
this was also a question asked.. I got the manual to work on my car, but it doesnt say much about this stuff because thats a "take it to a specialist" kinda work.. SO here comes the newb questions.. How can you reset the ECM and or where is it located.. as well as the IAC motor.?
If we change to a 65 throttle body do we have to change the injectors as well as the mass air flow sensor? if we need to what is recomended.. How easy or hard are all these changes??
are the injectors as simple as unplug and plug in??
which oil pump for a 406? high volume or high pressure? 406 ss monte Engine 23 09-10-2006 07:48 PM
85' corvette idles high WakBordr7387 Engine 6 12-30-2005 12:33 PM
Can you build a High Performace Engine that runs idles smooth? Jag Daddy Engine 16 01-23-2004 02:11 AM
Emissions HELP cutsupreme Engine 33 12-27-2003 08:22 AM
More Info, High RPM to Shift on 700R4 Ted Bundy Transmission - Rearend 3 11-25-2003 05:44 PM
