Idling over 5000, Valve Covers Leaking - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2002, 07:45 PM
Post Idling over 5000, Valve Covers Leaking
Engine runs great, but idles way to high. I tried everything with the carb and its perfectly fine. No links are broken nothing is staying open or sticking open for that matter. Whats else could be wrong?? Also my valve covers are leaking near the rear of the engine. I was given a Dress Up kit. What can I do to stop the leaking?? Thanks
Zee
Old 07-10-2002, 09:16 PM
Post
idling over 5000? thats pretty damn high. u better check teh carb again. chrome always leaks. not much ui can do about it.
Old 07-11-2002, 03:26 AM
Tom Tom is offline
Post
Hey Zee try another carb. that carb has probably got a serious leak,might be the well plugs,might be float stuck or saturated,might be bad needle and seat,might just be bad, might be something missing bent or broken
Old 07-11-2002, 06:19 AM
WoodsEdge's Avatar
Post
Check for vaccum leaks, try neopreme gaskets on valve covers.
Jack
Old 07-11-2002, 08:12 AM
New Member
Post
If you have positive crankcase ventilation the oil leak could actually be your vacuum leak.
Old 07-11-2002, 10:23 AM
Mrfixmaster's Avatar
Last journal entry: Red, my second T--Bucket
Post
Hate to sound stupid, but are you sure it's ideling at 5 grand? ? Could the tach be bad or does it soundlike it's running that fast??? <img src="confused.gif" border="0">
Old 07-11-2002, 11:03 AM
Madd Syntst's Avatar
American Madd Man
Post
Chrome valve cover are nice, but... Most of the dress up kits are very "tinnY" so they don't hold as well. You can try different gasket widths and, take you time doing it. Set the gasket to the cover and let it be over night. When installing them, don't be a yard ape and torque them down.
Slyfox hit on another very good point on vaccum leaks(I see your up the street from me as well)
You have two issues. Idle and leak. Fix one, then the other. Personally, I lean to the vaccum leak thing.
