idling problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2010, 07:58 AM
idling problems
i have a volvo s60 which is experiencing problems of slow idling and everytime i press brakes the engine goes off
Old 08-15-2010, 08:39 AM
delawarebill's Avatar
stalling motor??
first i'd be looking into the power brake sys.. its sucking all the vacumn out of the intake there by killiing any air/fuel getting into the motor...then again, i''ve never worked on a volvo so i may be totally wrong.. but thats where i'd start.
Oh and u really don't need to post twice...
Old 08-15-2010, 04:51 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Typically power brakes are assisted by a vacuum booster.
When you press the brake pedal a small valve is opened which allows engine vacuum reduce pressure on a diaphram inside the brake booster assembly.
This diaphram assists you in pressing the master brake cylinder push-rod.
If this diaphram has leak, air will be drawn into engine. This then changes the fuel air ratio (lean) in the engine causing it to stall.
A way to test this is to disconnect the vacuum hose leading to the brake booster and plug the line. For safety reasons don't drive the with this hose disconnected.
Start the engine to see if the stalling problem is gone. If so replace the booster.
vicrod
81' Corvette Idling Problems ckpena Electrical 3 12-07-2008 06:32 AM
81' Corvette Idling Problems ckpena Engine 2 12-03-2008 01:06 AM
350 - No oil pressure at 500rpm idling topdogger Engine 9 05-06-2007 06:18 PM
New/old 350 problems...someone help me!!! Warrant Engine 18 09-20-2006 09:53 PM
beater car problems 02 0n 20s Engine 2 11-01-2003 07:53 PM
