if i have 33 12.50s - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2006, 08:51 PM
if i have 33 12.50s
If i have 33s on my truck it has a 305 so it dont push them well what kind of gears do i need for it.? And how much would they be? Thank you
Old 03-16-2006, 09:03 PM
Twistedwrench's Avatar
No officer I won’t do it again
I use this place a lot. Great prices and customer service. Call or email and ask for Craig. Tell him what you want and he will set you up.
http://www.zbag.com/index.html
Old 03-16-2006, 09:20 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
First question is what gears do you have now? I'll guess you either have 3.42s or 3.73s. If thats the case you might want to move to a 4.10.
What year is your truck? If it's got a Dana 44 up front it might still have the tag hanging from one of the cover bolts. If it does then that tag should tell you the gear ratio and the number of teeth on the ring gear and on the pinion. If there is no identification on the cover you can pull the cover and count the the number of teeth on the gears by hand then divide the ring gear total by the pinion gear total to find your ratio.
Old 03-16-2006, 11:43 PM
from what i hear is that the 305 is not a very good engine i have a 1969 cj5 with a buick 225 and thats a v6 and i run the same tires but the gears and everything else is just stock so the only thing i did to it was put on those tires so mabe a a differnt engine may be good
Old 03-17-2006, 01:51 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
A good ratio for 33's is in the 4.10 and up range.
The smaller engine you have the more gear you will need, same with overall vehicle weight.
The transmission you have behind the engine will also make some difference too.
33 Willys Sedan Frsnitz Hotrodders' Lounge 8 11-25-2006 09:39 PM
33 or 34 forum south65ss Hotrodding Basics 5 02-27-2006 11:49 AM
How big Ford '33 interior door pulls? Limey Simon Interior 9 02-27-2004 07:25 AM
woodkit for a 33' chevy 6T2Burb General Rodding Tech 1 03-15-2003 02:55 AM
INFO FOR 33 WILLYS DossWallace Suspension - Brakes - Steering 1 07-20-2002 06:13 PM
