-   Modern Electronic Engines (http://www.hotrodders.com/forum/modern-electronic-engines/)
-   -   If you change the fuel filter and the engine stop running the next day, what might th (http://www.hotrodders.com/forum/if-you-change-fuel-filter-engine-stop-running-next-day-218339.html)
against all odds 04-19-2012 06:54 PM
If you replace the fuel filter and the next day it stops running, what might that mean?
NOTES:
1) It is a triton(or one of those "modular"?) engine if that makes any difference; It IS NOT MINE---i would never buy ford---only gm for me. i am trying to impress people at work with my knowledge of cars.
LATECH 04-19-2012 07:55 PM
2 Attachment(s)
NOTES:
It might mean you waited to long before replacing the fuel filter.I have seen pumps die after filter changes, only because the pump was allready damged by the filter being plugged and overheating the pump too many times,
Also, maybe the filter was installed bacwards and the media caved in and plugged the outlet. Just a thought.
My Triton runs sweet and it has 185,000 miles on it. Of course i maintain it.
Ford chevy whatever, they all get crappy if you dont take care of them.
Here is a pic, and last picture bump. :thumbup:
66GMC 04-19-2012 08:03 PM
I was thinking along the same lines.
"Why was the fuel filter changed to begin with?"
I guess it's human nature to hope / assume that the cheapest fix is the best fix. :D
PS.
Also agree with the "They're ALL junk when they don't run" philosophy. :mwink:
T-bucket23 04-20-2012 06:38 AM
Also someone may have twisted or kinked a line or damaged one of the fittings.
Also don't assume it is a fuel problem. Put a gauge on it and check the pressure to be sure. Assumptions can cost a lot of time and money
TurboS10 04-22-2012 08:42 PM
I'd check direction as mentioned as well as if the fuel pump is running. Go with easy first.
