If you change the fuel filter and the engine stop running the next day, what might th - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 04-19-2012, 06:54 PM
Banned User
If you replace the fuel filter and the next day it stops running, what might that mean?
NOTES:
1) It is a triton(or one of those "modular"?) engine if that makes any difference; It IS NOT MINE---i would never buy ford---only gm for me. i am trying to impress people at work with my knowledge of cars.
Old 04-19-2012, 07:55 PM
LATECH's Avatar
NOTES:
It might mean you waited to long before replacing the fuel filter.I have seen pumps die after filter changes, only because the pump was allready damged by the filter being plugged and overheating the pump too many times,
Also, maybe the filter was installed bacwards and the media caved in and plugged the outlet. Just a thought.
My Triton runs sweet and it has 185,000 miles on it. Of course i maintain it.
Ford chevy whatever, they all get crappy if you dont take care of them.
Here is a pic, and last picture bump.
ID:	64841   Click image for larger version
Old 04-19-2012, 08:03 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I was thinking along the same lines.
"Why was the fuel filter changed to begin with?"
I guess it's human nature to hope / assume that the cheapest fix is the best fix.
PS.
Also agree with the "They're ALL junk when they don't run" philosophy.
Old 04-20-2012, 06:38 AM
T-bucket23's Avatar
Wiki Edits: 26
Also someone may have twisted or kinked a line or damaged one of the fittings.
Also don't assume it is a fuel problem. Put a gauge on it and check the pressure to be sure. Assumptions can cost a lot of time and money
Chet
Old 04-22-2012, 08:42 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
I'd check direction as mentioned as well as if the fuel pump is running. Go with easy first.
Recent Modern Electronic Engines posts with photos
Fuel filter element change question BuzzMachines General Rodding Tech 1 07-07-2011 09:07 AM
Looking for a fuel filter cover or a metal fuel filter. Suggestions? (pic) rajsid Engine 3 08-05-2009 07:31 PM
Sunfire, died and wont start back, fuel pump is running, no gas getting to filter jordan2011 Engine 6 04-21-2008 06:01 AM
fuel injected engine needs fuel filter autonut Engine 3 04-13-2008 08:54 AM
engine running hot after cam change sam83k10 Engine 8 06-18-2006 04:55 AM
