If you could build any engine, what would it be? and what would yo put it in?
I would start with a Indy bbcrysler aluminum max block bored to 4.80 with a 5" stroker crank. a set of wiseco 10.5-1 pistons, 6.8 eagle 3d rods.
jesel timing belt set up . external oil system
heads would have to be Indy 600-13 heads with 2.40 int 1.90 ext valves with jessel 1.6 roller rocker .
cam - 297 int 305 ext @ .006 lift dur .690 lift int & ext 110 lobe sep roller cam.
Indy single plane manifold with 1250 dominater
2 1/8 primary 4" collecter custom made headers.
If I could build something like this I would put it either in a 68 barracuda or a 70 duster and run it in the pump gas 10.5 street class. its nice to dream isn't it.
