If you want an accurate estimate, techinspector1 has said the following is needed:
DYNOSIM REQUIRED DATA.... Bore Stroke Rod Length Cylinder head flow, intake and exhaust 0.100" through 0.700" or whatever the mfg gives for range Intake valve diameter Exhaust valve diameter Static compression ratio CFM, type of induction (2-bbl, 4-bbl, TBI, TPI) Intake manifold type, mfg (single 4-bbl, two 4-bbl, one 2-bbl, three 2-bbl, individual runner Weber, mechanical fuel injection, low-rise, high-rise, tunnel ram, dual-plane, single-plane, part no. if you have it. Exhaust system (be specific, primary tube size if long-tube headers) I have quite a library of CompCams (give me part number, not grind number) in my files, but if you are using another mfg, I'll need type (flat, roller, solid, hyd.), intake valve lift, exhaust valve lift and the following timing info and at what tappet lift the info is valid...(0.006", 0.050") I can calculate from 0.020" if I'm given enough information, but again, that takes my time. Intake opens ______BTDC Intake closes ______ABDC Exhaust opens______BBDC Exhaust closes______ATDC |
Bore 4"
Stroke 3.48 Rod Length 5.7 Cylinder head flow mfg only states .100 through .500 Intake valve diameter 2.02 Exhaust valve diameter 1.6 Static compression ratio 9.51:1 CFM, type of induction single 4-bbl carburetor Intake manifold type dual plane manifold Exhaust system long tube 1-5/8" Compcams part number for camshaft (12-211-2) |
List the cam specs, don't make us go looking for them.
Need those head flow #'s from .100"-.500" or you won't get good results. Need the intake specifics, brand and name. Carb brand and size. Header collector size and length. The more specific you can be about everything the better the results will be... You know, like computers....Garbage in, Garbage out |
First post has flow numbers up to 0.500", but no cam specs...
TI has said it takes a good chunk of his time to run these numbers, so anything that you do to make it easier, the better your chances of getting results. He's run hundreds (thousands?) of sims, so if it's just another plain vanilla SBC deal (in other words- another "same-old same-old" sim), you need to provide everything you can- and like ericnova72 said- that inclused printing out the cam specs and not just a link. If I were to make a WAG, I'd say around 400 HP and similar TQ. |
Cam Specs
RPM Range: 1800 to 5800 Valve Timing: .006 Lobe-Center Angle: 110 Intake Centerline: 106 Valve Lash: hydraulic Duration: Intake: 270 Exhaust: 270 Duration @ .050" Lift: Intake: 224 Exhaust: 224 Valve lift: Intake: 0.47 Exhaust: 0.47 Lobe Lift: Intake: .313 Exhaust: .313 Valve Timing @ 0.006 Lift: Intake opens __29____BTDC Intake closes __61____ABDC Exhaust opens___69___BBDC Exhaust closes___21___ATDC RHS Pro Torker Vortec Head Flow chart Intake: (2.02) Runner size 170cc .100-77 .200-155 .300-220 .400-263 .500-270 Exhaust (1.6) Runner size 67cc .100-74 .200-140 .300-168 .400-172 .500-174 Edelbrock Performer Rpm Dual Plane vortec manifold Not sure on Carb Brand yet but a single 4 barrel around 650 cfm Hope this helps! |
350/375 From The Air Head Dyno
I thing you're sucking on a dry titty, dyno sim guys are on vacation or just not giving it up. I say 350/375, you probably doing one HP per CI and a bit more torque. Check me out TECH INSPECTOR, please tell me I'm close.
Quick online calculation shows 411 hp @ 5600 rpm, with a 5800 rpm shift point. I used www.speedwaybids.com online dyno, figured 1600ft elevation and 90% volumetric efficiency.
It's just a quick program, maybe the Techinspector will come along, he has DynoSim IIRC. I lost my good program to a hard drive failure. |
| larger compressor | gburgess2002 | Garage - Tools | 13 | 07-19-2009 09:36 AM |
| Its Time..... | ZMaster | Introduce Yourself | 3 | 09-11-2006 11:28 PM |
| Time window after primer,body filler, color ,clear | BIG DOG | Body - Exterior | 3 | 07-20-2006 09:13 PM |
| How do you find time?? | kwman | Off-Topic | 18 | 01-11-2006 05:48 PM |
| Can someone run these numbers on there Desk Top Dyno? | black66 | Hotrodding Basics | 7 | 06-02-2004 02:52 PM |
