IFS front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2007, 10:49 AM
IFS front end
How difficult is it going to be to change out the solid front axle on my 50' chevy flat bed to a newer mustang IFS.
Any suggestions?
Old 03-28-2007, 11:34 PM
If your truck is a 3100 series with a flat bed ... there are many companies making a cross member to do just that ... pretty simple really.
If your truck is a large 1 ton or larger truck ... the Mustang II front end is not rated to carry that kind of weight.
Old 03-29-2007, 12:13 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
There are many different ifs kits for your truck. In fact Chassis Engineering makes a bolt in one - no welding.
http://www.chassisengineeringinc.com/page10.html
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 04-09-2007, 02:36 PM
IFS for my 50' Chevy Flatbed
Deuce thanks for the reply, it is a 3600 3/4 ton, i am going to take off the flatbed and install a regular bed on it, I am converting it to a hot rod instead of leaving it stock.
Do you think the Must. II IFs will still fit ok?
Old 04-09-2007, 03:28 PM
I am not a real authority on the Mustang II ... but I have done a few. My main concern was the weight of the flat bed truck with a load ... if you are just playing ... and not using it as a 1000 lbs ( or more ) hauler ... you should be fine ...
A 3/4 of a ton is 1500 pounds and with the curb weight of the truck ... it would weigh a good bit more than a Pinto or a Mustang II ... did from the factory.
Chevy truck Tilt front End! Onestophotrodshop Body - Exterior 0 12-01-2005 12:26 PM
Front end mock up shows some problems, cut n weld or frame shop? Ripped Body - Exterior 9 11-26-2005 08:03 PM
Mustang II front end Question horvath Suspension - Brakes - Steering 35 03-02-2003 05:08 PM
is there any front end alignment people out there? IHAVECHEVYPARTS Suspension - Brakes - Steering 5 11-26-2002 08:10 PM
Tables of rear end and front end dimensions willys36@aol.com Transmission - Rearend 1 08-21-2002 06:33 PM
