ifs help whith my 50 chevy pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2009, 12:38 AM
I need some info on my 50 chevy pickup i have a amc pacer front end i was thinking of putting it under my truck just wanting to know the pros and cons of this set up before i start in
Old 08-05-2009, 09:51 AM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
I have done a couple of those installs years ago and they work very well. You will likely have to reduce the P/S pump volume and pressure if you are using a GM pump. If you can find one, the Pacer wagons had anti-roll bars for the front ends.
Andy
Old 08-06-2009, 06:13 PM
Ck LMC, Brothers as one of them sold two mounting brackets that allowed for easier installation of the entire assembly. Ck to see if you can find ball joints for the Pacer as well! I did not use the assenbly for my a 49 because I could not find ball joints. I did find two about a year too late, but cannot remember if it was the upper or lowers that I could not get. Ditto on cut 1/3 of the spring off a GM pump. Rack and Pinion were available as rebuilt only from NAPA a couple of years ago, have not ck'd recently.
ld
Mustang II IFS in 59 Chevy p/u bucko2 Suspension - Brakes - Steering 1 10-09-2008 09:33 PM
Wheels for a 1967-72 Chevy Pickup 68ChevyMan Introduce Yourself 1 07-26-2004 10:09 PM
66 chevy pickup frontend swap pugster Suspension - Brakes - Steering 1 07-09-2003 11:50 AM
Windshield Frame for '54 Chevy Pickup horvath Body - Exterior 5 03-31-2003 06:07 PM
