Try www.ford-trucks.com to get some more opinions and articles. I just did a quick search over there:
Mustang II IFS is doable There is a company Fat Man Fabrications that apparently specializes in stuff like this Several people suggested refit of a late 60s-early 70s Ford full size car suspension (in my opinion this is for the more advanced individual, unless you find a detailed how to). If it was me I would buy a Mustang IFS kit from a reputable supplier that can provide some instructions and tech support. That will cost a few bucks but be less risky than inventing on the fly. Enjoy, sounds like it will be a nice vehicle. By the way, that site also has a detailed series of articles on IFS for pre-61 trucks..... a lot of the info will apply. Your truck had twin I beam instead of solid axle, that changed the frame some but not the concepts involved. |
Search other brands
The install of a mustang IFS or for that matter other choices of IFShas been covered in other threads..
Actually ince you are into the job it is nt all that much different a task on any brand of truck to do that job.. try widening your search parameters.. OMT
Thanks for the Reply's Guys.
I was also looking at a Chevy Type front end (Nova/Camaro) I can get the Front end off the car for $100.00 and have seen before just haven't been able to find it yet where someone else used a Nova front end and liked it. Thanks for the Links and Heads Up on where to look... Looks like I have alot more reading to do... Thanks, Chris |
We also used an AMC Pacer front end under a '47 Chevy Pickup and it also works quite well. Best of luck. |
Sorry if I am a bit late on this thread but here is my input...
I have a 66 Ford Twin I Beam truck and I looked on ways to lower it, etc and see that everyone with these 60's-70's trucks use a Dodge Dakota front end. They say you can use a Mustang but I hear the Dodge Dakota are better. Now I am not sure WHY they are better or used more but I am guessing they came off a truck so can take more weight... Look into this more, you may be able to find a dakota in a junk yard and cut that baby right off. www.slick60s.org Go there and look up the info, they have a guy on there that did the switch with info, if you can't find it then either do a search or ask it again. May take a week to get some answers but eventually they will give you the best possible answer you will need. Hope this helps! |
| IFS for 27 Track T Roadster | Dave Carpenter | Suspension - Brakes - Steering | 16 | 01-15-2012 06:15 AM |
| Need IFS help on 1934 Plymouth | rusttorod | Suspension - Brakes - Steering | 16 | 08-31-2007 10:19 PM |
| TCP Vs. Fat Man IFS | 1965-Mustang | Suspension - Brakes - Steering | 9 | 11-25-2003 05:01 PM |
| windsor info | Blag | Engine | 1 | 04-24-2003 08:08 PM |
| fender - IFS fit | brandler | General Rodding Tech | 9 | 04-03-2003 07:01 AM |
