Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - IFS installed on 57 F100
Old 02-19-2004, 08:13 PM
Darkman270's Avatar
Darkman270 Darkman270 is offline
I was unable to line up the lower control arm pivot with the rear strut rod mounting point which is actually a pivot too. This was due to my frame width. I could have, as Willys36, did put a factory rear strut mount that was widened. Ideally a piece of 1/2" allthread running through the lower control arm bolt holes should also shoot a bullseye through the rear strut mounting bracket.
