IFS installed on 57 F100 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2004, 09:17 PM
Darkman270's Avatar
I am truely a brave man to post these pictures. I know that I will be told what I did wrong. Really I appreciate the criticism so don't hold back. First I'll say that I added a triangular box to the top of the Fatman crossmember. It is welded to the inner boxing plate that we installed. It is 1/4" wall. I felt like it would reduce the frame flexing strengthening the overall design. I am not happy with the strut alignment with reference to the lower control arm pivot bolt but I worked with what I had. This will not be a racer or daily driver and will see infrequent trips out on mostly good roads. We also added a gusset to the strut rod mounting bracket. I am open to suggestions on how to improve this. Here are a few pics .
OK I guess I can only do one at a time.
Name:	2004 - 02 04 fatman ifs install bottom drivers side w arm and strut 2.jpg
Old 02-12-2004, 09:22 PM
Darkman270's Avatar
Here is second picture.
If someone can tell me how to put the image in the text it would be nice.
Name:	2004 - 02 03 fatman ifs mods finished rear view.jpg
Old 02-13-2004, 02:06 PM
RAW's Avatar
RAW RAW is offline
It is now Saturday, everyday!!
Last journal entry: Project '57 Ranchero
IFS Gussets
I'm still bench assembling my Fatman Stage III but my plan is to add the frame inboard and outboard gusset as you have installed. In fact I making cardboard "go-bys" for the shop. r
Old 02-14-2004, 07:21 PM
jalopy45's Avatar
Cool
Nothing wrong with the gussets! It may be overkill but that is a good thing, Go ahead and drive it everyday. Looks like you got a good start on the chassis.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 02-15-2004, 02:16 PM
Darkman270's Avatar
Thanks for the comments guys. One day I may build a real rod as opposed to rebuilding a stocker. I envy the latitude you have when it comes to mixing and matching parts. I need to keep mine stock APPEARING to keep with my project mission. Don't get me wrong I'm enjoying it but sometimes I feel like I'm in a box. A very small box. LOL
Old 02-16-2004, 09:18 AM
deuce_454's Avatar
looks great. but while you are at it i would go ahead and box the rest of the frame, it will improve your ride emensly, it will stiffen the rails many thousand times. and make for a much more modern ride (an x member wont hurt either- but boxing is cheap and easy in your stage and will help alot)
Old 02-19-2004, 07:54 PM
RAW's Avatar
RAW RAW is offline
What did you mean by...
" I am not happy with the strut alignment with reference to the lower control arm pivot bolt but I worked with what I had."
Are you discussing the parallels with the lower arm shaft and the upper arm mounts. While bench assembling I was concerned about the "anti-dive" and the upper arm shaft. I'm installing a stage III but curious about your comment.
thx, r
Old 02-19-2004, 08:13 PM
Darkman270's Avatar
I was unable to line up the lower control arm pivot with the rear strut rod mounting point which is actually a pivot too. This was due to my frame width. I could have, as Willys36, did put a factory rear strut mount that was widened. Ideally a piece of 1/2" allthread running through the lower control arm bolt holes should also shoot a bullseye through the rear strut mounting bracket.
Old 02-20-2004, 12:53 AM
deuce_454's Avatar
i have installed an OEM MII in my 32 roadster, and i have cut the strut rod and welded on a tube that holds a bushing to gain some room arround my engine. but the mountings are still on the inside of my frame
i think you should re do it to get the pivot point right, because unless you have a very stiff front suspension that hardly mooves you are going to get some funny allignment changes throughout the travel of the wheel. The easiest is propably to buy a triangulated lower contrill arm that elimitates the strut rod. that will also loose some of the sloppyness the SOFT strut rod bushings add.
Old 02-20-2004, 05:10 AM
Wiki Edits: 49
There are a couple different strut rods. As I understand it the Pinto strut rods had a slightly different bend in them than the Mustang rods. This may be where your problem lies.
Usually all you have to do is heat the strut rod with a torch and make the necessary bend to line up with the frame.
Hope this helps.
Centerline
