2 inches isn't all that much drop. I have installed them 1 inch higher than the crossmember was designed to be installed at, but not 2. The upper a-arm perches usually won't allow 2" . It does require extra fabrication . You can adjust the ride height an inch either way with a coilover setup. That would get you to stock height. If you don't like the idea of that then you could call fatman fabrications and see if they have a c-member designed for something else that will put the truck at stock height, or maybe they can make 1 up. hope this helps, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
Yeah your right, 2 inches isn't that bad, but when you look at the height of the front straight axle and leaf springs and the height of the chassis, it looks like it will be dropped more than 2", more like 6-8, but I could be wrong, remember I am new at this.
Me and my best freind I grew up with used to build hopped up engines, and I would paint his car, etc, but really never any body or frame fabrication, onlt building engines, doing paint and body work but never cutting any panels or chassis, this is going to be my first. I want to use the original chassis and keep my cost down somewhat. I looked and Fatman Fab, and I see their prices range from $4,999-$12,000. Of course what you want with it depends on the cost. Last edited by TheHarleyMan2; 02-05-2006 at 06:15 AM. |
Ifs
I have a 39 panel. Contact Fat Man Fabrication in Charlotte, NC they make a great product and are super to work with. They make kits for almost anything and will make it to suit. It rides and handles as well.
I have a friend who installed a early 90's Silverado chassis under a early 50's Suburban. Not a BOLT IN deal but not bad either.....it sits about like it was when stock and has PS, Power Disc Brakes and late model parts availability. Plus is is heavy duty enough to carry the weight......unlike some of the compact car front ends some rodders put under heavy vehicles ...
I'm not sure of how far you want to go with chrome and stuff but 4999.00 to 12000.00 is alot to pay for an IFS. (Man, if you will pay that let me send you my phone#. JUst kidding LOL) The basic hub to hub kits start at 1800.00. here is the page I saw
http://www.fatmanfab.com/06page5.htm the kits are easy to install if you are proficient with a welder and a measuring tape. If you want to know at just what height your truck will sit at when the IFS is installed , ask for the spindles height as it relates to the frame. Heidt's shows this in their catalog as a distance from the bottom of the frame to the spindle centerline. Heidts says their kit will put the spindle C/L at 2 13/16 above the bottom of the frame with their 2" dropped spindles or 13/16" above the bottom using their stock spindles. I would assume fatman is close to that. The ride height can be adjusted up or down from there about 1"either way. You could probably go more but then you start changing the geometry. If you call one of the suppliers and give them your desired ride height expressed as spindle height above the bottom of the frame, there will be no misunderstanding. Hope this helps, mikey Quote:
| 1948 Chevy Thriftmaster 3/4 ton truck 5 window | therock | Suspension - Brakes - Steering | 10 | 03-25-2007 12:57 AM |
| Metal shrinking with a torch.....57 Chevy qtr. panel | pasadenahotrod | Body - Exterior | 5 | 02-26-2003 10:38 AM |
| 1948 chevy fleetmaster inner fenders | cardsrusa | Body - Exterior | 3 | 01-15-2003 10:14 AM |
| 46 Chevy Panel, HELP ME!! | Bluepen | Suspension - Brakes - Steering | 2 | 01-05-2003 12:02 PM |
| IFS and 30 chevy coupe | moondoggy | Suspension - Brakes - Steering | 1 | 06-10-2002 06:19 PM |
