Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - IFS Swap question
Old 09-09-2004, 06:46 PM
astroracer's Avatar
astroracer astroracer is offline
Fred,
I have to agree with Adv. Des. Make the frame fit the suspension BUT, like he mentioned, verify track width before you cut it up too much. Measure the distance between the wheel mounting surfaces on both vehicles. If the '81 is too wide you can usually compensate a bit with a positive offset wheel. Keep us in the loop.
Mark
