Ignition boxes???which is best?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2008, 02:03 PM
Robbie's Avatar
Last journal entry: nova
summit has came out with ignition boxes of there own,and i was wondering if anybody has used one yet,and if so,how well does it work???I havent never used an ignition box but i would like too..Im running a tunnelram and after tunning it for ever it seems, it still runs alittle rich,and i was told an ignition box would give me more spark ,and help to burn more gas in each cylinder...the one im looking at is sum-850602 summit brand
Old 09-02-2008, 02:46 PM
malc's Avatar
Born To Be Mild
Iīve had an MSD6A box for a long time but recently I went from an HEI magnetic trigger to an MSD distributor and coil, MSD-8361 distributor ,
MSD-8207 coil .
Itīs a great setup and has done wonders for my idle.
I have got one of the Summit boxes as well, itīs still boxed so I canīt help you on that yet.
I bought it for some reason now forgotten so while the MSD performs well Iīll keep it in reserve.
Old 09-02-2008, 05:31 PM
Stroke Meister
Tunnel ram, eeewwww. They're fine for beating the hell out of, but I've never seen one set up that was as good as a single four on a single plane. JMO
Old 09-02-2008, 06:56 PM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
I like the Summit dress up alum parts they are nice stuff and most plane no logos. As to ignition well you want good consistent fire for that fuel. I run MSD, but I am going to run Crane on the truck, no real reason for switching just want to try another quality ignition system.
With electronics you are paying for the type, size and spec. correct components. You will get what you pay for in this area even if you can not see the difference
Just food for though.
Old 09-02-2008, 07:22 PM
Robbie's Avatar
well i guess mine is the first,cause i have beaten the hell out of alot of 4 barrel carb on a single plane
Old 09-02-2008, 09:08 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
My friend had and msd 6a and it started making a real bad buzzing sound. He switched to the summit box and its been running good for about 4 months now. The summit box is just a rename of the mallory box.
Old 09-03-2008, 06:56 AM
bubbahotep's Avatar
the specs for each box is different and you do get what you pay for. Theyre probably all equally good if the models you compare have the same outputs.
I've had an msd6a box and timing computer for about 17 years I think with winter freezing temps and summer heat and no known complaints.
Old 09-03-2008, 06:14 PM
hey malc
Hi, Malc,
Just wondering why an MSD distributor would idle better than a MSD crank trigger. What was the problem?
thnx, jack vines
Old 09-04-2008, 03:30 PM
malc's Avatar
Born To Be Mild
Originally Posted by Packard V8
Hi, Malc,
thnx, jack vines
Never had a crank trigger, I had installed the MSD trigger in the HEI taking out the original module etc.
The MSD distributor and separate coil work better for me.
Old 09-04-2008, 08:55 PM
I have a Crane Hi 6 box....the short version of the story is after a small under hood fire the wires to the box were a little fried. Shipped it back to Crane with a note saying if you can fix it I will pay. They sent me a NEW box no charge with a Thank You for using out product letter... it was well past any warranty date and I had Visa in hand to pay for the damage....they even paid for the shipping! If customer service is worth something to ya buy the Crane box......Lorne
Old 09-05-2008, 09:03 AM
bentwings's Avatar
bentwings
I just got the Summit street strip box with the rev limiter to replace a toasted MSD ( would not warantee). I spent an hour on the phone with a great tech at Summit sorting out a no spark issue. It boiled down to a bad coil (another fine MSD product). Bottom line the new box works just fine and throws a spark from h**l. haha
Funny this is the box bolted right in, including the wires. It even came with the long extension for the MSD dist.
Great item.
Old 09-05-2008, 12:33 PM
I have used jacobs box on a 450 hp 355 chev. Used it with a mallory procomp 5000. AWSOME!!!!!!!!!!!!!
Old 09-08-2008, 07:26 AM
Robbie's Avatar
thanks guys
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Ignition - No Spark DaytonaCoupe Electrical 3 07-04-2008 10:28 PM
Help me pick- Electronic Ignition Coil Francis Electrical 27 04-24-2006 05:11 AM
Big Time Ignition problem!!!!! 70chevy Engine 2 06-24-2004 04:41 PM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
