Ignition coil, maximum distance from engine? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2009, 06:37 PM
Highway's Avatar
Highway
What's the farthest I can mount an ignition coil from the distributor? I have a mopar 400 big block with a standard mopar electronic distributor. The engine is in an 85 Dodge Ram. I would like to mount the coil on the firewall a little to the left side of the engine but it would require about 2.5 to 3in coil wire.
Thanks,
Highway
Old 11-03-2009, 07:24 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Thanks,
Highway
2.5 - 3 inches of coil wire? That would be great. Or did you mean feet?
Old 11-03-2009, 07:29 PM
T-bucket23's Avatar
Wiki Edits: 26
Thanks,
Highway
I have seen 3' long coil wires with no issue. As long as you use a quality wire.
Chet
Old 11-03-2009, 07:33 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Is'nt the distributer in the front of the engine on the 400 mopar? The coil wire will be just alittle longer then 2.5 or 3 inches don't you think if coil mounted on the firewall.JMO............Cole
Old 11-03-2009, 08:58 PM
sqzbox's Avatar
My pipes are my music
The firewall isn't the best place to put an external coil, alot of heat there.
I had mine mounted on the fenderwell hump. Need less than two feet of wire.
Old 11-04-2009, 02:54 PM
Highway's Avatar
Highway
Woops....Yep I meant feet.
Actually sqzbox, I have no fenderwells. I was planning on mounting it along with the ECU on my blower/heater deletion plate. I was thinking it would get plenty of air being that close to the wheel well opening.
Old 11-04-2009, 07:22 PM
blue54's Avatar
Mounting it on your plate will place it in a direct path for any thing coming off the tires. Might be better to place it on the core support or if it has to be there build a shield to cover it. As to the 2' to 3' distance, with good quality wire it should not be a problem.
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 12:53 PM
no power getting to my ignition coil dearta223 Electrical 1 08-01-2009 10:36 PM
Ignition Coil resistance Question Old School Nut Engine 3 06-11-2005 04:36 PM
capicator for coil?? points ignition HELP jadye Electrical 2 04-30-2004 11:17 AM
Ignition and engine advice Jare Engine 2 03-09-2004 03:21 AM
