Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ignition coil overheating??
Old 09-14-2012, 07:56 AM
timothale timothale is offline
Wiki Edits: 27
resistor,
Usually coil overheating is caused by running the wrong coil , one that requires a ballast on Bat voltage, did they give you the correct coil?
