Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ignition coil overheating??
Old 09-21-2012, 12:58 AM
chevyrestore's Avatar
chevyrestore chevyrestore is offline
I noticed a mechanical type ticking noise from the motor today while it was misfiring, im thinking valve lash/ possible bad lifter now.
If it ends up needing a lifter will it damage the cam to put a new lifter and pushrod on whatever cylinder is making the noise or what should I do considering I am using the same camshaft?
I did just replace the intake gasket, is there any possible way to replace the lifter without removing the intake manifold?
