Ignition coil overheating??
Chevyrestore, Check the distributor. First make sure the spark plug wires are right. You will need an assistant. The #1 tower is the 2nd one from where all the wires plug in under the cap, going in a clockwise direction. An easy way to find #1 is to hook up your timing light to #1 spark plug wire. Pull #1 spark plug and bump the engine over until air is coming out around your finger. Turn the key switch to the on position. Look to see if the line on the balancer is near 0 on the timing scale. Take a socket and breaker bar and turn the crank bolt while holding the trigger on the timing light. Stop when the light flashes. You can rock the crank back and forth to get the light dead on. Turn the key off. Pop the cap to see where the rotor is pointing. If the rotor is not pointing to the #1 tower I said the distributor is in wrong. BTW check the cap make sure you don't see any carbon trails from the center button. You can rewire the cap starting where the rotor is pointing with #1 then in a clockwise direction 8-4-3-6-5-7-2. Fire the motor up and set the timing at 12*-16* BTDC. If you still hear the tapping noise adjust the valve lash again. Here's the article on how to install a distributor. http://www.crankshaftcoalition.com/w..._a_distributor
I removed that one pushrod and blew threw it, felt somewhat free, after blowing through it it felt a little bit more free and looking through it I can see its totally clean inside, reinstalled, same thing, no oil from that one pushrod, I ran it with that lifter loose, no clatter, and 1/2 turn tighter after the clatter stopped. I dont think its the adjustment or pushrod itself, the pushrod also appeared unbent
Adjusting valve lash
There's absolutely no problem replacing one lifter or anything less than a full set, but you need to do the same breakin on it that you'd do with a whole new cam/lifter set.
I'd also be looking at that ProComp distributor for the cause of your misfire. When they start to go the electronics will break down when warm or hot, and develope a misfire. It may be signaling you that it's failing. They don't have a great reputation. |
Chevyrestore, I sent you a PM.
No oil to the rocker arm.
Chevyrestore, There is two ways to do this. You could pull the lifter and take it apart to clean it. You could also purchase the same brand lifter and swap the inside parts to your lifter. This way you don't have to go through the whole break-in process again.
I took off the rocker arm on that valve and there was no damage to it preventing oil from getting all the way through, there was a very small ring of what looked like a burn mark.
Excellent idea! Never thought about rebuilding the bad lifter and saving breakin time!
Grounding is very important to electronic ignition systems, so it could be that if the engine and system isn't properly grounded, but it usually wont be heat related. It should happen all the time if it was a ground issue.
when I get some time away from work im going to pull off the driver side valve cover this time and check out the travel on the rockers and readjust,
at this point based on your suggestions I may be leaning towards a distributor also if the driver side ends up checking out good. Also on a side note, should I be running the vacuum advance on the driver side (manifold vacuum) or passenger side (ported vacuum)? |
Do a search on this website for Distributor Vacuum Advance Control units
Specs and facts for GM Distributors by Lars Grimsrud SVE Automotive Restoration Musclecar, Collector & Exotic Auto Repair & Restoration Broomfield, CO Rev. B 8-19-02 It may be easier to type this in the search block and go to post #9. Port or Full time vacuum - Hot Rod Forum : Hotrodders Bulletin It will be the second thread. Last edited by cdminter59; 09-23-2012 at 11:51 PM. |
From what I have learned and read in the past everyone said to use manifold vacuum since I dont have any emission requirements. I was also told though that with certain misfire problems many people ran with ported vacuum which is why I was asking.
When its hooked up to manifold vacuum it definitely has a deeper more throaty sound because of the lack of advanced timing at idle. Has anyone else on here experienced switching from ported to manifold advance help with misfires under load? |
What is your timing curve? initial_____ mechanical_____. You want 36-38 total. This only leaves around 14*-16* for Vacuum advance. If your vacuum can is adding more you will have to buy an adjustable one. As for you not getting oil to the #5 rocker what we are saying is the lifter is not pumping oil up thru the push rod. Take the lifter apart to see if you have some trash in it or buy another lifter(same brand) and take the inside guts and install in your lifter body. This way you won't have to go thru a break-in process again. With your vacuum unhooked from your distributor is your idle high enough without using the curb idle screw on your carburetor? If it is okay you can use ported vacuum. If the idle is too low use manifold vacuum to raise the idle.
| Ignition coil | RichardT | Electrical | 1 | 01-16-2012 01:01 PM |
| Help, coil overheating | grizmo | Electrical | 2 | 03-15-2010 07:41 AM |
| overheating coil | Mertz | Electrical | 3 | 04-25-2007 06:16 PM |
| DIS ignition, Visteon Corp. coil on plug / MSN coil per cylinder | Costa Rica | Electrical | 0 | 06-30-2005 02:13 PM |
| overheating ignition module??? | dh79 | Electrical | 3 | 07-16-2004 12:45 PM |
