Ignition coil overheating?? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 09-27-2012, 05:28 PM
chevyrestore's Avatar
Just to eliminate this procomp crap I bought a few years back I bought an MSD 8361 distributor. The wiring directions only show it going to different types of controllers, can I wire this one directly to the coil or do I need the controller box as well?
  #32 (permalink)
Old 09-27-2012, 09:29 PM
Msd 8361
That model requires an ignition box. Can you return it and get the MSD 8360? MSD Ignition 8360 - MSD Pro-Billet Ready-To-Run Distributors - Overview - SummitRacing.com
  #33 (permalink)
Old 09-27-2012, 09:30 PM
yeah MSD gave me the wrong number, I reordered the right one, thanks
  #34 (permalink)
Old 09-27-2012, 10:29 PM
I think I read in your posts that you purchased the Blaster High Vibration MSD-8222. Just want to make sure you have a good coil for your new distributor. When installing your new distributor make sure it is grounded good and the battery lead is disconnected. Don't want you to burn up the module.
  #35 (permalink)
Old 09-28-2012, 07:17 PM
Thanks for the info, will the MSD-8222 be okay with the MSD distributor I ordered?
  #36 (permalink)
Old 09-28-2012, 10:01 PM
Yes, The MSD-8222 is all you will need. The instructions to wire it up should be in the box.
  #37 (permalink)
Old 10-21-2012, 09:41 PM
Hey everyone, with all youre help I think its fixed, I replaced the coil and distributor with MSD parts and that fixed it so far...thanks for everyones help and hopefully this forum thread will help someone with the same issue
  #38 (permalink)
Old 10-21-2012, 11:44 PM
Well, I hate to rub it in because I know everyone wants to save money anyway that is possible. When installing new parts especially high performance parts buy the known brands that work. If something is $100 cheaper for the same part warning signs should go off in your head! Buy the correct part once, use a coupon or another store that has a sale. I have saved alot of money buying name brand parts using coupons from the internet from stores such as StreetsideAuto.com, SummitRacing.com (No coupons lately). It pays to compare prices. Glad everything has worked out for you!
  #39 (permalink)
Old 10-22-2012, 10:09 AM
Actually the Root Cause of your problem could have been an impedance mismatch between the Procomp electronics in the distributor and the MSD coil. I know that Procomp advertises that this works with anybodys anything coils but that's likely to be more advertising than engineering. There is a good chance that the Procomp module would work happily with a Procomp coil. Or that putting the MSD module into the Procomp distributor would have solved the problem.
One of my big issues with the hot rod industry is the lack of genuine technical data 70% more power than brand X's coil is not really useful information. Our ignition module is impedance matched to a 50 ohm coil is useful engineering data.
Back in the good old days of modular stereo systems if you plugged 16 ohm speakers into a 8 ohm amplifer you could count on buying new speakers or amp, or both in the not to distant future. You've got a same/simular situation here between distributor module and coil another exists in the drivers for fuel injectors between high and low impedance injectors get this wrong and you will find youself buying a new computer or new injectors or both.
So whether this is a problem of Procomp being of less quality or whether it was caused by using their distributor module against an MSD coil remains an open question in my mind, a spare time experiment someday perhaps.
Bogie
  #40 (permalink)
Old 10-23-2012, 12:44 AM
Bogie
I know this is a procomp being cheap problem because I tried 2 MSD coils, and 2 procomp coils, both procomp coils worked for a few months then gave out, also had 3 vacuum advance canisters go out and my truck never backfires and 1 distributor go out for bearing noise. From what ive gotten from procomp its all junk apparently.
Ignition coil RichardT Electrical 1 01-16-2012 01:01 PM
Help, coil overheating grizmo Electrical 2 03-15-2010 07:41 AM
overheating coil Mertz Electrical 3 04-25-2007 06:16 PM
DIS ignition, Visteon Corp. coil on plug / MSN coil per cylinder Costa Rica Electrical 0 06-30-2005 02:13 PM
overheating ignition module??? dh79 Electrical 3 07-16-2004 12:45 PM
