Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ignition/ coil/ points?
Old 02-11-2013, 09:53 PM
choirboy choirboy is offline
Correction on last post. The wire at solenoid was NOT on the "I" terminal, it was on the other small terminal which I believe is the "F" terminal. That terminal has 12 volts while in "run" position. Car was already wired when I got it. I don't know how or why this problem did not surface before. I guess I will get ANOTHER resistor and try this again with wire attached to the "I" terminal. Any more input is greatly appreciated.
