Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ignition/ coil/ points?
Old 02-12-2013, 06:53 AM
delawarebill's Avatar
delawarebill delawarebill is offline
resistor
a resistor is blow not short.. but i guess there's an exception to every rule.. ask yourself... does the engine start up fine??? if so remove the wiring from the starter to the coil !!!! and just run from resistor.. my bucket engine makes maybe 2 rpm's and starts right up.. so i do not use the starter wire to coil...
