ignition,coil, and starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2012, 04:39 PM
im wiring up a 67 chevy ii, with a accel breakerless dist, mallory promaster coil, and of coarse a chevy starter, before i ruin my harness, what wires go where
Old 01-31-2012, 05:13 PM
EOD Guy's Avatar
Chevy color code.... should have a purple wire from the key switch to the "S" terminal on the starter, The other terminal on the older starters was for the old point/coil type dizzy.... the wire from the pos side of the dizzy went to the "I" terminal on the starter to provide full 12v to the coil while starting. After it starts the "I" went dead and the coil received 9ish volts from the run position on the key switch via a resistance wire... ballast resistor etc..... so you wouldn't burn up the coil.
Modern HEI dizzy run on 12v ....so no need for the resistor or the "I" terminal.
Old 01-31-2012, 05:49 PM
thanks, i diddnt want to burn anything up, i just bought a painless harness, and i love it, it was just the difference in my 72 nova with points still that i was looking at what to compare, it just diddnt make sense, im on the right track now, pretty soon the neighbors will hear what open headers sounds like again,
Ignition coil RichardT Electrical 1 01-16-2012 02:01 PM
MSD Ignition coil ap0001 Electrical 8 01-16-2011 07:09 AM
ignition coil smokin63 Engine 1 02-22-2008 08:36 AM
ignition coil patpoza Electrical 2 02-04-2007 01:06 AM
DIS ignition, Visteon Corp. coil on plug / MSN coil per cylinder Costa Rica Electrical 0 06-30-2005 03:13 PM
