Ignition coil suspected of being faulty...how to test it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2005, 03:05 AM
Steve-0321's Avatar
How do i go about checking if its the coil that is fault or the wiring. I took the coil plug off the distributor and cranked the engine and watched the spark....the first two cranks were blue sparks as i thought they should be but then they turned to yellow and stayed that way. Is this a faulty coil...or is it polarized perhaps...maybe the wiring leaking energy. Any suggestions will be gratefully appreciated.thanks
Old 10-15-2005, 05:40 AM
docvette's Avatar
Wiki Edits: 12
Answer in Engine forum...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Ignition system info................ poncho62 Electrical 18 10-11-2008 11:10 PM
Help me pick- Electronic Ignition Coil Francis Electrical 27 04-24-2006 06:11 AM
Ignition Coil resistance Question Old School Nut Engine 3 06-11-2005 04:36 PM
capicator for coil?? points ignition HELP jadye Electrical 2 04-30-2004 11:17 AM
SB Chevy Ignition coil resistor frackster66 Electrical 5 11-26-2003 11:03 AM
